lmjlars
Oct 07, 2012Aspirant
ReadyNas DNS problem
Hi, Have searched and found numerous reports on how to fix the ReadyNas (in my case ultra) DNS problems. Most of them refer to switch to DHCP. None of them are resolving my problem, which is that t...
Oct 07, 2012Guru - Experienced User
Are you using DHCP? If not, what IP address and subnet are you using?
