lmjlars
Oct 07, 2012Aspirant
ReadyNas DNS problem
Hi, Have searched and found numerous reports on how to fix the ReadyNas (in my case ultra) DNS problems. Most of them refer to switch to DHCP. None of them are resolving my problem, which is that t...
lmjlars
Oct 08, 2012Aspirant
Hi Stephen,
I'm using DHCP, and all IPs seem correct (same Gateway and DNS-adresses as all my other computers. All Computers (Including the ReadyNas) are behind a NetGear Prosafe FVS338, all computers except for the ReadyNas can access internet.
Last night I also did a factory reset and after that a test SSH:ing to the ReadyNas, and tried to ping some external adresses (including the DNS). All packets Lost. Did the same at the same time with another computer on the same network, and no packets were lost.
These are the Network settings (all assigned by DHCP):
IP: 192.169.0.19
SubnetMask: 255.255.255.0
Gateway:192.169.0.1
DNS:192.168.1.254 (have also tried with 192.169.0.1)
All Computers (working) on the network use the above settings for subnet, gateway, DNS.
StephenB wrote: Are you using DHCP? If not, what IP address and subnet are you using?
IP: 192.169.0.19
Gateway:192.169.0.1
