lmjlars
Oct 07, 2012Aspirant
ReadyNas DNS problem
Hi, Have searched and found numerous reports on how to fix the ReadyNas (in my case ultra) DNS problems. Most of them refer to switch to DHCP. None of them are resolving my problem, which is that t...
lmjlars
Oct 08, 2012Aspirant
Well, there is another router (ADSL-modem) in front of the FVS338. That's where the 192.169.1.254 adress is originating from. The ProSafe is the 192.169.0.1. The reason I'm using 192.169 is pure inheritance. I doubt however that that would be the reason for why the ReadyNas is not resolving or even being able to ping adresses outside the Network.
Adresses resolved by other computers, also behind the nat, (for instance www.google.com or ftp.sunet.se) will not work on the ReadyNas, but works perfectly on other computers behind the NAT.
Pinging from the ReadyNas:
ultra:~# ping 194.71.11.69
PING 194.71.11.69 (194.71.11.69) 56(84) bytes of data.
^C
--- 194.71.11.69 ping statistics ---
7 packets transmitted, 0 received, 100% packet loss, time 6000ms
Pinging from another computer:
$ ping 194.71.11.69
PING 194.71.11.69 (194.71.11.69): 56 data bytes
64 bytes from 194.71.11.69: icmp_seq=0 ttl=52 time=33.784 ms
64 bytes from 194.71.11.69: icmp_seq=1 ttl=52 time=33.458 ms
64 bytes from 194.71.11.69: icmp_seq=2 ttl=52 time=33.741 ms
64 bytes from 194.71.11.69: icmp_seq=3 ttl=52 time=34.637 ms
64 bytes from 194.71.11.69: icmp_seq=4 ttl=52 time=33.883 ms
64 bytes from 194.71.11.69: icmp_seq=5 ttl=52 time=35.148 ms
64 bytes from 194.71.11.69: icmp_seq=6 ttl=52 time=33.948 ms
^C
7 packets transmitted, 7 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 33.458/34.086/35.148/0.547 ms
^C
$ ping 194.71.11.69
^C
