sdiring11
Feb 19, 2021Aspirant
ReadyNAS Duo - Can't connect to shares
I cannot access my shares. After many years of working flawlessly, I cannot access the shares. The device shows up on RAIDar. I can access the admin page. I have the host name specified in the ho...
- Feb 22, 2021
Maybe try running CMD on the PC and enter
net use * /delete /y net use t: \\192.168.1.251\C /user:admin nas-admin-password
using the actual NAS admin password of course. The first command will terminate any open SMB sessions, the second will attempt to map the C volume to drive letter T.
If that fails, I suggest rebooting the PC and trying a second time.
Sandshark
Feb 20, 2021Sensei
Possibly SMB1 got turned off by a Windows update. See if it's on in "Turn Windows Features On and Off".
Windows will caution you about it being unsafe, but it is my opinion that home users typically don't need to worry about it so long as they are not opening ports to the outside.
sdiring11
Feb 22, 2021Aspirant
I am running Windows 10. I vefified that SMB 1 is turned on. I am seeing it on multiple devices. I got a new laptop working by adding SMB 1. Then, a few days later the laptop and the dekstop that had been working for years stopped accessing the shares. Both can ping and go to the admin page. Access through HTTP/S is working but I want regular access.
- SandsharkFeb 22, 2021Sensei
Are your user name and/or password on the NAS different than on the PC, and do you have any drive mappings that don't have those credentials saved? If yes, then a recent update to Windows breaks that. It used to complain the user name and password were wrong and let you change them.., Now, it just tells you they're wrong and gives you no way to fix it.
- StephenBFeb 22, 2021Guru - Experienced User
- sdiring11Feb 22, 2021Aspirant
Worked perfectly. Many thanks.
