sdiring11
Feb 19, 2021Aspirant
ReadyNAS Duo - Can't connect to shares
I cannot access my shares. After many years of working flawlessly, I cannot access the shares. The device shows up on RAIDar. I can access the admin page. I have the host name specified in the ho...
- Feb 22, 2021
Maybe try running CMD on the PC and enter
net use * /delete /y net use t: \\192.168.1.251\C /user:admin nas-admin-password
using the actual NAS admin password of course. The first command will terminate any open SMB sessions, the second will attempt to map the C volume to drive letter T.
If that fails, I suggest rebooting the PC and trying a second time.
Sandshark
Feb 22, 2021Sensei
Are your user name and/or password on the NAS different than on the PC, and do you have any drive mappings that don't have those credentials saved? If yes, then a recent update to Windows breaks that. It used to complain the user name and password were wrong and let you change them.., Now, it just tells you they're wrong and gives you no way to fix it.
Feb 22, 2021Guru - Experienced User
