bazbrian1
Jul 16, 2011Aspirant
ReadyNAS Duo - DLNA - Panasonic BWT700GL
I have a Netgear ReadyNAS Duo 2000 firmware 4.1.7 that has DLNA turned on. I'm looking at the Panasonic DMR-BWT700GL as a new HDD Recorder. http://www.panasonic.com.au/Products/DVD+and+Blu-ray/Blu-ray...
arjoseph1
Jul 17, 2011Tutor
I believe that no actual test have been made for obvious reasons. NETGEAR cannot not afford testing all DLNA compliant devices to work with the ReadyNAS. Since it complied with the standard then it should work.
