bazbrian1
Jul 16, 2011Aspirant
ReadyNAS Duo - DLNA - Panasonic BWT700GL
I have a Netgear ReadyNAS Duo 2000 firmware 4.1.7 that has DLNA turned on. I'm looking at the Panasonic DMR-BWT700GL as a new HDD Recorder. http://www.panasonic.com.au/Products/DVD+and+Blu-ray/Blu-ray...
Gandhionaharley
Dec 29, 2011Aspirant
Hi All,
I have a Panasonic Viera ST30 tv and a Panasonic blue ray BDT1100.
If I use the TV to connect to my ReadyNas then it can play most video files on my server, and the blue ray can play almost none. So I think the issue must lie with device you are using to access the server. They must not have the ability to play those file types.
