james_b1
May 26, 2013Aspirant
ReadyNAS Duo - factory reset jammed?
Hi I updated RAIDar, performed a factory reset on my ReadyNAS Duo (with a paperclip), went out, came back nine hours later and it still is not finished. Has it hung up and should I pull the plug and...
May 26, 2013Guru - Experienced User
Try holding down the power button to shut it down.
If you can delete the partitions on Mac, then that would be good. This link suggests that you can do that. http://macs.about.com/od/applications/s ... size_5.htm
