james_b1
May 26, 2013Aspirant
ReadyNAS Duo - factory reset jammed?
Hi I updated RAIDar, performed a factory reset on my ReadyNAS Duo (with a paperclip), went out, came back nine hours later and it still is not finished. Has it hung up and should I pull the plug and...
james_b1
Tried the power button but that didn't work. I pulled the cord, rebooted, and nothing seemed to have changed, and nothing reported in the log... unfortunately I cannot see the ReadyNAS using the disc utility, although I can see it fine with "Finder"... should I try "Perform Factory Default" from Frontview?
