james_b1
May 26, 2013Aspirant
ReadyNAS Duo - factory reset jammed?
Hi I updated RAIDar, performed a factory reset on my ReadyNAS Duo (with a paperclip), went out, came back nine hours later and it still is not finished. Has it hung up and should I pull the plug and...
May 26, 2013Guru - Experienced User
You can access Frontview? And see shares in Finder?
So (a) what is frontview reporting for volume status and disk status
(b) Are you seeing an empty volume with Finder?
