james_b1
May 26, 2013Aspirant
ReadyNAS Duo - factory reset jammed?
Hi I updated RAIDar, performed a factory reset on my ReadyNAS Duo (with a paperclip), went out, came back nine hours later and it still is not finished. Has it hung up and should I pull the plug and...
james_b1
Thanks..
(a) It appears to be reporting two hard drives as before with 927 gb allocated per drive
(b) No, it is not empty, no files appear to have been removed whatsoever by the failed factory reset.
