james_b1
May 26, 2013Aspirant
ReadyNAS Duo - factory reset jammed?
Hi I updated RAIDar, performed a factory reset on my ReadyNAS Duo (with a paperclip), went out, came back nine hours later and it still is not finished. Has it hung up and should I pull the plug and...
May 26, 2013Guru - Experienced User
ok. Did you also check the SMART stats?
What are you wanting to accomplish with the factory reset?
