fvalls84
Jul 16, 2013Aspirant
ReadyNas Duo - Freezes / Hangup
I have two ReadyNas Duo's. The one causing the problems I have had for a couple of years with no issues. Last week I noticed the Nas was hung up because I was unable to load a movie. When using the ...
fvalls84
(a) are you seeing anything in the logs or health? Check the SMART stats for both drives, and also the ethernet stats (network interfaces, show errors).?
Just the typical "Volume scan found and corrected errors." Everything says and seems "ok".
(b) have you ever deleted the log files?
No, they got back to 2011
(c) do you have ssh access?
I did turn on FTP for the first time in May. Forgot that I did.
I wanted to see if I could make it easier to access from the outside for various projects but I ended up forgetting about it.
I just turned it off. It would be weird that this caused the issue since I have had no problem for a little over a month with FTP turned on.
Anyway, the answer is no.
- Jan 17, 2024Retired_Member
