Kimomac
Jul 19, 2011Aspirant
Readynas Duo 3TB owned
Hello! I don't know if that's the right place to post this message but my problem is I got sold a ReadyNas Duo & two 3TB Caviar Green 64mb, and can't return any of those... :( I just figured t...
Kimomac
Thank you TeknoJnky.
I will try to sell my RDN Duo on ebay.
Which specific replacement would you recommend? I see there are ReadyNas Ultra 2, Ultra 4, Ultra 6... Is the Ultra 2 x86 based?
I'm on budget, so I'd like the cheapest solution possible to take advantage of my two 3TB WD drives...
Thanks you very much in advance
