Kimomac
Jul 19, 2011Aspirant
Readynas Duo 3TB owned
Hello! I don't know if that's the right place to post this message but my problem is I got sold a ReadyNas Duo & two 3TB Caviar Green 64mb, and can't return any of those... :( I just figured t...
TeknoJnky
Jul 19, 2011Hero
yes all the ultra's are x86 based and support 3tb drives.
I would assume the ultra 2 would be the cheapest, but if if you can swing it I would recommend the ultra 4, this will give you even better expansion options for the future, with the 4 bays.
