fraschub
Sep 18, 2019Aspirant
readynas duo blue power LED blinks permanently
I'm using a netgear readynas duo with 2 250gb disks for years without any problem. yesterday, after an power interruption the NAS starts again but does not come to an end. That means the blue front L...
fraschub
Sep 19, 2019Aspirant
thanks for your reply.
1. start of Raidar show the message that an update is available. I have 4.3.1. Latest is 4.3.8
Without an update (so far I hesitated to do this) the Raidar shows only the startscreen with help information. Seems that update is inevitable ?
2. Yes, I have an backup on an usb hard disk, but over the years there are some old data only on the NAS, so data loss is a concern
3. RAID: from my notes it seems that the NAS ist set to 'X-Raid (extendable RAID) with 2 disks'
4. blink patterns: I haven't paid attention to blinks during start. So I cannot say anything about the number of slow blinks during start
because from tne moment I noticed the trouble the blue LED is blinking slowly but permanently. No other LED is on.
Hope that helps to
Sep 19, 2019Guru - Experienced User
It would be good to know if RAIDar can find the NAS. There's not much risk in updating it - if that were to fail we'd be in the same situation we are in now.
That's good to know. So we need to be careful to minimize data risk.
If we can see the NAS status in RAIDar, that would give us a better handle on what we dealing with.
But no matter what it tells us, I think we will need to test the disk drives. So after you give the upgrade a shot (and see if you can get more specific NAS status), you should
- power down the NAS
- remove disk 1 (perhaps label it by slot number)
- try powering up the NAS and see if it boots.
If it does boot normally, then make a fresh USB backup right away.
If it doesn't then just power the NAS back down again.
If you don't have a Sata->USB adapter kit (or a USB dock) you will likely need one. You can test use that to test the disks in a Windows PC using vendor tools (lifeguard for western digital; seatools for seagate). Not sure they will work with your version of windows; hopefully they will.
There is also a free Windows utility you can use to extract the data from disk 1. https://www.r-studio.com/free-linux-recovery/ Again, I have no idea if that will work with XP. Could you get access to a newer OS (maybe from a friend). Win-7 or Win-10.
