Carrie142
Dec 17, 2015Aspirant
ReadyNAS Duo connection failed on new iMac
My old iMac died and I got a new one and transferred everything using a Thunderbolt cable. I can see the ReadyNAS drives, but when I click on them, it says "Connection Failed." I installed RAIDar_Mac...
- Dec 18, 2015
Carrie142 wrote:
It says NETGEAR ReadyNAS Duo RND2000 v2 on the bottom.
Read the link I posted.
Carrie142 wrote:
There is an ethernet cable running from the drive to my computer. So it isn't physically connected to my router. I'm not sure if it connects to it over wifi?
Normally the NAS is connected to your router. You should then be able to access it over WiFi connections. NAS-> "Network Attached Storage".
How did you access the NAS before you upgraded the MAC?
Dec 18, 2015Guru - Experienced User
The part number in the post says you have a duo v1 (which runs 4.1.x firmware). the current production version is 4.1.14, though 4.1.15-T3 "beta" is better - it isn't really a beta, rather it has a few important security updates that are missing in 4.1.14.
There is more info on v1/v2 model identification here: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
The screen in your link is for the v2, and you have a v1. Normally the NAS is updated from the web ui - of course that isn't possible if the NAS network connection isn't working.
Is the NAS connected to your router?
Carrie142
Dec 18, 2015Aspirant
It says NETGEAR ReadyNAS Duo RND2000 v2 on the bottom. There is an ethernet cable running from the drive to my computer. So it isn't physically connected to my router. I'm not sure if it connects to it over wifi?
