pwop
Nov 24, 2012Aspirant
Readynas duo daisy chain to Thunderbolt issues
I need some help as I am in way over my head. I upgraded to a new Macbook Pro with thunderbolt display. I also bought a Promise Pegasus DAS. I connected my Netgear NAS to the Promise with a Etherne...
pwop
mdgm wrote: I didn't say to change the range of addresses used by your router. Your Mac would be trying to connect to your NAS via your router but it can't.
Under Airport's "Network options" one can set the IPv4 DCHP range and it can only be 10.0 or 172.16 or 192.168 plus whatever else you choose for the third and fourth values as the range. It was set to 10.0 and I changed it to 192.168 as I thought that would work better with the NAS with a default, it seems, of 192.168.168.168.
