pwop
Nov 24, 2012Aspirant
Readynas duo daisy chain to Thunderbolt issues
I need some help as I am in way over my head. I upgraded to a new Macbook Pro with thunderbolt display. I also bought a Promise Pegasus DAS. I connected my Netgear NAS to the Promise with a Etherne...
pwop
mdgm wrote: I didn't say to change the range of addresses used by your router. Your Mac would be trying to connect to your NAS via your router but it can't.
Shouldn't the MAC try to connect to the NAS via the Ethernet-Thunderbolt adapter that the NAS Ethernet cable is plugged into? The NAS is not connected to the router now.
The Thunderbolt connection goes from the Macbook to the Thunderbolt screen to the Promise Pegasus DAS to the NAS via the adapter.
