hander1
Dec 16, 2011Aspirant
Readynas Duo: Dead drive 1 - what are my options?
Drive 1 just reported as dead. Rebooted and running OK on drive 2. Is there anything I can do to check disk 1 before getting it replaced under warranty? If it isn't covered for some reason, would...
mdgm-ntgr
Dec 16, 2011NETGEAR Employee Retired
You can connect it to a SATA port on your PC and check it using vendor tools
It doesn't matter what 1TB or greater capacity disk you use so long as it is on the Hard Disk HCL
