DPIPIMHouse
Jan 17, 2012Aspirant
ReadyNAS Duo drops off LAN
Hi, I'm new to this forum because I've never had a problem with my Duo until now. Hopefully someone can help. I recently moved house and when starting my Duo up for the first time, I was unable to...
Jan 17, 2012Guru - Experienced User
The first step is to back up your data! RAID doesn't guarantee data loss - lots of posts on this topic in the forums.
The second step is to test the second disk in your PC with vendor tools (WD lifeguard in this case).
If your disks are on Netgear's HCL, then you could also open an on-line support case.
