mallman
Mar 23, 2012Aspirant
ReadyNAS Duo error flashes, Tech Support Case 18205894
Hello, I have a ReadyNas Duo (RND2000 V2 it says on the bottom) which I bought July 2010. It has 2 2GB disks in it. Monday I turned it off by pressing the power button for 5 secs, since the mains h...
mdgm-ntgr
Mar 23, 2012NETGEAR Employee Retired
It's a Duo (v1). The Duo v2 was released November 13th 2011. NetGear labelled some Duo (v1) units e.g. RND2000 v2 presumably long before they decided to release a new product called the Duo v2. The RND2000 v2 sticker indicates a minor hardware change compared with earlier Duo (v1) units. Probably useful for NetGear troubleshooting defective units received via RMA.
Can you see the NAS in RAIDar (http://www.readynas.com/downloads)? If so what do you see. Of particular interest would be what you see under the Info (far right) column.
