mallman
Mar 23, 2012Aspirant
ReadyNAS Duo error flashes, Tech Support Case 18205894
Hello, I have a ReadyNas Duo (RND2000 V2 it says on the bottom) which I bought July 2010. It has 2 2GB disks in it. Monday I turned it off by pressing the power button for 5 secs, since the mains h...
mdgm-ntgr
Mar 23, 2012NETGEAR Employee Retired
stueyb please open your own support case. NetGear has a method of remotely diagnosing problems (if needed) and if they do need to do this they can provide instructions on how to set this up. They may have a record of what the light pattern means and be able to quickly identify what the problem is.
