lenscooter
Aug 22, 2014Aspirant
ReadyNAS Duo freezes during resync - what to do?
Hi! I've had my faithful ReadyNAS Duo with 1 TB drives in RaidX config for many years and it's worked like a charm. But this morning I got a message that one of the drives was showing increasing numbe...
Aug 22, 2014Guru - Experienced User
Running 4.1.6 means it is a v1 for sure. The link explains the mismatch on the back label. There are differences between the platforms, so it does matter when providing advice.
lenscooter wrote: I don't know if it's a v1 or v2, it says RND2110 v2, FW V4.1.6. But according to the linke you provided, it's a v1 based on the outline of the rear. Does it matter?
BTW 4.1.6 is very old firmware. After you fix your disk issues you should update it.
I will follow your suggestion to power down and pull out disk 1 (which is the most likely suspect based on the messages I got).
No.
lenscooter wrote: Do I need to move disk 2 to slot # 1 after pulling the #1 disk?
- Jan 17, 2024Retired_Member
