lenscooter
Aug 22, 2014Aspirant
ReadyNAS Duo freezes during resync - what to do?
Hi! I've had my faithful ReadyNAS Duo with 1 TB drives in RaidX config for many years and it's worked like a charm. But this morning I got a message that one of the drives was showing increasing numbe...
Aug 23, 2014Guru - Experienced User
Since this is purely a backup NAS, even if it fails totally you can do a factory reset, and bring it back to life and simply re-copy the data. So it might not matter which you try.
I'd be tempted to remove the faulty disk, and see if the NAS recovers.
If it does, then you could hot-insert the replacement.
Otherwise pull the plug.
Let us know how it works out.
- Jan 17, 2024Retired_Member
