davidacampbell
Feb 01, 2019Aspirant
ReadyNAS DUO guest shares work with Win10 with CIFS 1.0 option, but authenticated shares don't work
Here's my situation:
1. ReadyNAS Duo with latest 4.1.16 firmware.
2. Windows 10 client with SMB 1.0/CIFS File Sharing Support Option installed.
3. Shares configured with Guest access...
davidacampbell
Stephen,
Thanks for your reply. The net commands you mentioned worked straight off, even despite previously having rebooting the computer and it continuing to not work. I could then access the t: share.
After running your net commands, I tried re-deleting the shares with the /delete command and then connecting by simply opening \\nas\files from the start menu and it worked.
Somehow incorrect credentials must have been cached and the delete seems to have fixed it.
The non-Windows SMB client I previously tested with was smbclient from linux, which can talk to SMB shares.
Feb 01, 2019Guru - Experienced User
Great! I'm glad you have access again.
