josepvr
Jan 10, 2017Aspirant
ReadyNas Duo just working directly connected to pc but not after switch
Hello, I have same issue explained in follwoing post the issue is I can only get connected to my NAS when I directly connect to my pc if i plug on a router or switch device is not accessible: ht...
- Jan 11, 2017
Hello!
just fixed the issue.
The problem was on NAS network interface configuration on Speed/Duplex mode configuration.
It was set to Automatic, after changing to 100Mbps Full duplex it started working in all previous cases.
Hope it helps other people with same issue.
PD: I'm not able to updat FW manually neither autmatically...
Jan 10, 2017Guru - Experienced User
Do you have a static IP address assigned on the Duo?
- josepvrJan 11, 2017Aspirant
Hello,
Thank you for your answer.
So, Yes! i'm using 192.168.0.140, wich is working when I directly connect to my laptop. (I tried different switch ports and ethernet cables that were working with my laptop but NAS doesn't get connected)
In addition, yesterday I tried to manually update FW but it fails while loading file.
- StephenBJan 11, 2017Guru - Experienced User
Is your router also using 192.168.0.x addresses?
yes it is.
I have tested just connecting NAS to switch not router (to avoid any interference with DHCP server) and i got same behavior.
