josepvr
Jan 10, 2017Aspirant
ReadyNas Duo just working directly connected to pc but not after switch
Hello, I have same issue explained in follwoing post the issue is I can only get connected to my NAS when I directly connect to my pc if i plug on a router or switch device is not accessible: ht...
- Jan 11, 2017
Hello!
just fixed the issue.
The problem was on NAS network interface configuration on Speed/Duplex mode configuration.
It was set to Automatic, after changing to 100Mbps Full duplex it started working in all previous cases.
Hope it helps other people with same issue.
PD: I'm not able to updat FW manually neither autmatically...
Jan 10, 2017Guru - Experienced User
Do you have a static IP address assigned on the Duo?
josepvr
Jan 11, 2017Aspirant
Hello,
Thank you for your answer.
So, Yes! i'm using 192.168.0.140, wich is working when I directly connect to my laptop. (I tried different switch ports and ethernet cables that were working with my laptop but NAS doesn't get connected)
In addition, yesterday I tried to manually update FW but it fails while loading file.
- StephenBJan 11, 2017Guru - Experienced User
Is your router also using 192.168.0.x addresses?
- josepvrJan 11, 2017Aspirant
yes it is.
I have tested just connecting NAS to switch not router (to avoid any interference with DHCP server) and i got same behavior.
This worked ok before, correct? Is there something that changed on the network (new router, etc)?
Also check that the LAN leds are lit on the duo and the switch (or router) when you connect it to the main network.
If the leds are lit, then see if RAIDar can see the NAS ( http://kb.netgear.com/20684/ReadyNAS-Downloads?cid=wmt_netgear_organic#raidar )
josepvr wrote:
I have tested just connecting NAS to switch not router (to avoid any interference with DHCP server).
The DHCP server spans the whole subnet, and switches don't change that. It would rule out a failed LAN port on the router.
What router are you using?
