josepvr
Jan 10, 2017Aspirant
ReadyNas Duo just working directly connected to pc but not after switch
Hello, I have same issue explained in follwoing post the issue is I can only get connected to my NAS when I directly connect to my pc if i plug on a router or switch device is not accessible: ht...
- Jan 11, 2017
Hello!
just fixed the issue.
The problem was on NAS network interface configuration on Speed/Duplex mode configuration.
It was set to Automatic, after changing to 100Mbps Full duplex it started working in all previous cases.
Hope it helps other people with same issue.
PD: I'm not able to updat FW manually neither autmatically...
josepvr
Jan 11, 2017Aspirant
Hello,
yes, NAS worked before then we disconnected (power supply and ethernet for some months).
Now i try to put it working again but it is working just when i directly connect to my PC.
Let me summarize my setups in order to clarify which case is working:
(all following cases setting static IP to NAS, 192.168.0.140 that is same subnet as my pc and all devices on home network. No other device has same IP)
- NAS -> PC = NAS connection OK but little bit slow
- NAS -> SWITCH -> PC (no other devices connected and all ports tested) = Nas Connection NOK
- NAS -> SWITCH -> PC (other devices connected and communicating well to my PC, all ports tested) = NAS connection NOK
- NAS -> Router -> PC (no other devices connected and all ports tested) = Nas Connection NOK
- NAS -> Router -> PC (other devices connected and communicating well to my PC, all ports tested) = NAS connection NOK
I've noticed that when connected to Switch or router takes long time to lit LAN leds (maybe 5 minutes).
EDIT1: When directly connecting NAS to my PC takes about 20 seconds to lit LAN leds (other devices connected to my PC takes less than 1 seccond to lit)
Other topic is, why I can not update FW when directly connected to my PC?
Thank you for your support.
josepvr
Hello!
- StephenBJan 11, 2017Guru - Experienced User
What firmware are you running?
The most common reason for not reaching the update server is forgetting to configure a DNS server in the network settings for the NAS. 8.8.8.8 works (it's google's open DNS server).
- josepvrJan 16, 2017Aspirant
DNS was OK because autoupdate screen shows me new update, but it fails when i request to update my nas.
- FramerVJan 17, 2017NETGEAR Employee Retired
Hi josepvr,
Are you able to make changes to the ReadyNAS settings, like maybe creating shares, back-up jobs?
Not 100% sure but the OS partition could full or filling up.
Do you receive an error message when upgrading manually?
What apps are installed on the ReadyNAS?
Regards, - StephenBJan 17, 2017Guru - Experienced User
Very possible. I suggest making a backup, and then deleting the log files on the NAS (w/o downloading them).
You could then the update again, and see if it works. Or just do a factory reset and reload the data from the backup.
