Tbag
Dec 14, 2012Aspirant
Readynas duo locked hard drives - SOLVED
Hi there this is my first post so forgive me if its not in the right section. I have recently purchased a readynas duo v2. The problem i am having is the unit boots and factory defaults on every re...
mdgm-ntgr
Dec 18, 2012NETGEAR Employee Retired
That output doesn't suggest the password is incorrect. It suggests you don't have sufficient privileges to run the command.
Try putting "sudo" (no quotes) before hdparm i.e. do sudo hdparm ...
