Indexmill
Sep 06, 2013Aspirant
ReadyNas Duo loses network mid-transfer
Hi All, I have two ReadyNas Duos on a home network with two Windows 7 PCs. All seems to be fine...until an Acronis Backup job running on either of the PCs fails about 4 hours into a 5-6 hour backup...
Sep 07, 2013Guru - Experienced User
I use acronis to back up to my pro, and generally haven't seen this issue. When I have seen it, the network was the problem (for instance if I did a backup over wifi).
These backups are going on at the same time? Do the symptoms change if you only run one?
Also, the destination is the NAS internal drives? Not USB?
How big are they? ~9 hours seems a long time for an image backup.
