carlovn66
Dec 12, 2015Aspirant
ReadyNas Duo losing access to shares
I have a problem where I am losing access on my computers to my shares on the ReadyNas Duo. After a NAS reboot, the shares are accessible for a while, but after some time becomes inaccessible with a ...
carlovn66
Dec 13, 2015Aspirant
Thanks for your response Stephen.
I did clear all the logs.
No, I don't have SSH enabled and I am not using ReadyDLNA. But I went searching for the SSH option, which I could not find. But I did find the FTP option and was able to start the FTP service. Now I am in the process of downloading all my data to an external drive and that seems to be working for now.
Where can I find the SSH option and can I use that to SSH to the NAS server or would that only give me access to the shares?
Unfortunately, I am running the NAS in Raid 0 (or is that 1) configuration where the one drive is a mirror of the other. I wanted the redundancy. Was that a bad choice? What would you recommend?
Presuming that I have all the data that I care about on my external drive, how do I go about fixing my system? Will a factory reset do it, or is it more complicated than that?
Again, thanks for your help. Much appreciated!!
sotrack
Dec 13, 2015Luminary
SSH add-on for Sparc based DUO:
http://kb.netgear.com/app/answers/detail/a_id/24546
SSH add-on for ARM based DUO:
http://kb.netgear.com/app/answers/detail/a_id/24586
login:
root/password_from_admin_user
- carlovn66Dec 14, 2015Aspirant
Thanks for the info.
- BrianL2Dec 14, 2015NETGEAR Employee Retired
Hi carlovn66,
Once you've finished backing up everything, factory reset the unit and use RAID 1 for redundancy (mirror).
Let me know if you have further questions.
Kind regards,
BrianL
NETGEAR Community Team
