2pods's avatar
2pods
ReadyNas Duo Mk2 Blue light booting forever
I added a 2gb Drive to the 2gb drive already in (both OK with the list) and it seemed to be expanding OK, but then it needed to boot and has been like that for about 12 hours.
Both drive panel lights are on in blue, but the blue activity light is flickering. Raidar has continued to tell me the unit is booting.
Both hardware and Raidar are up to date.
Help..!
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Perhaps power off the system, disconnect the power, wait a minute or two, then reconnect the power again and see if it boots.
  • Thanks that did it :D
    No I only have to work out how to use it as either a new share, or a redundant drive without losing what I have on the original.
    I've tried copying all of "Public" and "Media" to a attached 3tb usb3 drive, but It gives me I/O errors after copying some of the 1.7tb worth of files :nashammer:
  • I'm pressing the "download logs" button, but either nothing is happening, or they're being saved somewhere, but no idea where.
    mdgm-ntgr
    It can take a little time for the logs to be generated. Though if it doesn't work you could try a different web browser.
    mdgm-ntgr
    Are you able to connect the USB disk to your PC and test it?
    Also are you able to power down the NAS, remove your disks (label order) and test them using SeaTools?
  • Rebooted NAS both disks showing OK. Probably pilot error :-)
    I'll give the USB test a shot and report back
ProSupport for Business
