captjohnno
Oct 08, 2015Aspirant
ReadyNas Duo Network port issue
HI I have just moved house and therefore relocated my ReadyNAS Duo which is about 5 years old. I've had one HDD failure in that time so have new drives. At present it boots up but no network li...
- Oct 23, 2015It's official I'm an idiot.
Turned out to be that when we moved house I mixed up the power adapters from the Readynas and my Dlink router. The router was working with the Netgear adapter but as I thought there seemed to be a power issue with the readynas and that was because it was using a less powerful Dlink adapter. Not sure why it worked when I took it to my work office as I was still using the wrong adapter.
captjohnno
Oct 13, 2015Aspirant
Have bought a USB adapter/enclosure and linux reader software but cannot read the drive.
Therefore i assume it was Flexraid - any solution for that?
Can't believe an actual HDD hasn't failed yet i cannot get the data off it.
Oct 13, 2015Guru - Experienced User
Linux Reader can't read it at all? Or does it see the OS partition but not the data partition?
- captjohnnoOct 14, 2015Aspirant
Messages when i try and access the drives...
- StephenBOct 14, 2015Guru - Experienced User
The disks are different sizes. Did you have two volumes, or only one?
Can't recall to be honest but i know it was set-up to be mirrored or data duplicated on both drives so if one drive failed i had access to the other.
