captjohnno
Oct 08, 2015Aspirant
ReadyNas Duo Network port issue
HI I have just moved house and therefore relocated my ReadyNAS Duo which is about 5 years old. I've had one HDD failure in that time so have new drives. At present it boots up but no network li...
- Oct 23, 2015It's official I'm an idiot.
Turned out to be that when we moved house I mixed up the power adapters from the Readynas and my Dlink router. The router was working with the Netgear adapter but as I thought there seemed to be a power issue with the readynas and that was because it was using a less powerful Dlink adapter. Not sure why it worked when I took it to my work office as I was still using the wrong adapter.
captjohnno
Oct 21, 2015Aspirant
I plugged in again and although the lights come on it just sounds like it's the PSU not firing up. Could that be easier to replace?
Oct 21, 2015Guru - Experienced User
Replacing the Duo's power brick is easier than migrating to a new NAS, and the bricks aren't very expensive. It might not work of course.
- captjohnnoOct 21, 2015Aspirant
Great how do i get one?
- StephenBOct 21, 2015Guru - Experienced User
You can just google of course.
http://www.amazon.com/UpBright%C2%AE-Adapter-RND2150-100NAS-ReadyNAS-Switching/dp/B00EZDN1J0
Or contact support via support.netgear.com, and they can refer you to some suppliers.
