captjohnno
Oct 08, 2015Aspirant
ReadyNas Duo Network port issue
HI I have just moved house and therefore relocated my ReadyNAS Duo which is about 5 years old. I've had one HDD failure in that time so have new drives. At present it boots up but no network li...
- Oct 23, 2015It's official I'm an idiot.
Turned out to be that when we moved house I mixed up the power adapters from the Readynas and my Dlink router. The router was working with the Netgear adapter but as I thought there seemed to be a power issue with the readynas and that was because it was using a less powerful Dlink adapter. Not sure why it worked when I took it to my work office as I was still using the wrong adapter.
Oct 21, 2015Guru - Experienced User
captjohnno wrote:
I plugged in again and although the lights come on it just sounds like it's the PSU not firing up. Could that be easier to replace?
Replacing the Duo's power brick is easier than migrating to a new NAS, and the bricks aren't very expensive. It might not work of course.
captjohnno
Oct 21, 2015Aspirant
Great how do i get one?
- StephenBOct 21, 2015Guru - Experienced User
You can just google of course.
http://www.amazon.com/UpBright%C2%AE-Adapter-RND2150-100NAS-ReadyNAS-Switching/dp/B00EZDN1J0
Or contact support via support.netgear.com, and they can refer you to some suppliers.
