SixString1
Nov 27, 2011Aspirant
ReadyNAS Duo not mounting LVM volume?
I'm not exactly sure what's going on, but that's my theory. SYMPTOMS: My Duo won't boot with either (or both) of my drives in it. It will boot fine with no drives. (I had two 500GB Seagate drives ...
PapaBear1
Nov 27, 2011Apprentice
First - NO ReadyNAS is supposed to boot without at least one drive. Think of the flash memory as a typical OS install disk, the OS that the unit operates from is on the drives. No drives, no operating OS.
Second - In order to trigger the firmware re-install, the unit must be off and you must depress the micro switch behind the small hole on the back with a straighten paper clip while pressing the power button. You must hold the micro switch depressed until the first long (1 sec) flash of the lights at about 5 seconds. Do not hold for much longer. Here is the link to the instruction: http://www.readynas.com/?page_id=5029
