SixString1
Nov 27, 2011Aspirant
ReadyNAS Duo not mounting LVM volume?
I'm not exactly sure what's going on, but that's my theory. SYMPTOMS: My Duo won't boot with either (or both) of my drives in it. It will boot fine with no drives. (I had two 500GB Seagate drives ...
SixString1
I still don't seem to be getting the firmware to re-install. I tried holding only the reset switch and also holding the reset switch and the power button down.
I held them for 8 seconds but never got the single LED flash. The instructions say the factory reset occurs at 30 seconds; does that mean I could try 10-15 seconds safely? And do I hold just the reset or both?
