SixString1
Nov 27, 2011Aspirant
ReadyNAS Duo not mounting LVM volume?
I'm not exactly sure what's going on, but that's my theory. SYMPTOMS: My Duo won't boot with either (or both) of my drives in it. It will boot fine with no drives. (I had two 500GB Seagate drives ...
mdgm-ntgr
Nov 28, 2011NETGEAR Employee Retired
Contact NetGear tech support. They may be able to identify a problem from looking at your logs.
As for checking your disks: power down the NAS, remove the disks (label order), connect them to a SATA port on your PC and test them using vendor tools. Run both short and long tests.
