Krisztian
Mar 05, 2023Aspirant
ReadyNAS DUO not showing shares after disk failure, data usage still shows data is not wiped
Hi all, I had disk #1 failed another day and managed to resync the array with a spare disk but unfortunately the shares have disappeared, they won't show in admin web gui. The share is not acces...
Mar 05, 2023Guru - Experienced User
FWIW, you don't have a Duo (you must either have a 2-bay OS NAS, or a converted Ultra-2 or Pro-2). Fortunately you provided enough info to let us know the model was wrong.
Krisztian wrote:
How can I restore the previous state of the share on the ReadyNAS so it shows up again? running latest firmware 6.10.8
No idea how that happened, but there is a repair script you can try.
This was written by a Netgear developer for support use some years ago. Unfortunately, the last time I checked the certificate had expired.
However, you can still run it using these steps:
# cd //
# wget --no-check-certificate https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh
# chmod +x ./share_lun_ui_fix.sh
# ./share_lun_ui_fix.sh
make sure you are logged in as root (using the NAS admin utility).
Krisztian
Thanks Stephen for the reply. Yeah you right, I messed up the model, it is a RN31400, sorry about that.
I've run a disk Scrub and that seemed to restored the missing share for me, but I will definitelly save that script for another day.
Thanks again.
