GuitarMan86
Aug 22, 2013Aspirant
ReadyNAS DUO power loss and now green blinking lights
Hi All, I just experienced a power failure and the ReadyNAS DUO went down unexpectedly. When the power came back on the NAS was manually powered on by me. As the NAS powered up the blue power lig...
GuitarMan86
No, the unit is no longer under warranty unfortunately.
When accessing the boot menu which option should be chosen as to not lose data? The boot menu shows holding the power button and pressing reset button for however many seconds..... But not sure which option you're suggesting. Thanks
