GuitarMan86
Aug 22, 2013Aspirant
ReadyNAS DUO power loss and now green blinking lights
Hi All, I just experienced a power failure and the ReadyNAS DUO went down unexpectedly. When the power came back on the NAS was manually powered on by me. As the NAS powered up the blue power lig...
vandermerwe
Aug 22, 2013Master
If the data is intact the OS reinstall will not destroy data.
You may not be able to access the boot menu, at least if you can you could try an OS reinstall.
