GuitarMan86
Aug 22, 2013Aspirant
ReadyNAS DUO power loss and now green blinking lights
Hi All, I just experienced a power failure and the ReadyNAS DUO went down unexpectedly. When the power came back on the NAS was manually powered on by me. As the NAS powered up the blue power lig...
GuitarMan86
Aug 23, 2013Aspirant
I will try to work on getting to the data today using the Linux-reader software. Hoping that the drives should still be fine.
The only LED's that flash on the unit are disk 1 and 2 flash slowly. No pattern and no power light at all and the fan is on high. If both disks are removed the unit dies the same thing when booted.
Possible hardware issue with the unit? Never boots up and no power light with fan on high.
