MacNasMan
Feb 04, 2017Guide
ReadyNAS Duo, pulsing blue light
Noticing it since last night, pulsing blue light, and 2 solid HD lights. Since my server turns on and off every day, don't know for how long it was in this state. FrontView and file shares are not av...
- Feb 07, 2017
You'll have to do a forced power down if you can't access the system via frontview or ssh. And since you can't access the data, you can't back up the data before you do that.
Here's a decoder ring for the Duo leds:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configurationThis doesn't fit your pattern (since your HD lights are solid), but perhaps it might when you reboot.
Feb 07, 2017Guru - Experienced User
1 - Vendor mismatch
4 - Flash error
