nicolasg
Jul 19, 2017Aspirant
ReadyNas Duo really slow -- kswapd0 high
Hi Netgear community, My company has a ReadyNas Duo 102 (6.4.0) and we have several problems since few weeks. I "repaired" what I could but now I need your advices. Basically, the Nas became re...
Jul 19, 2017Guru - Experienced User
It's not a Duo (if you call it that, people here will reply as if it were a duo v1 or duo v2). It's just an RN102.
nicolasg wrote:
Using "top" command (ssh), I observe that the "kswapd0" is really using. It does not sound good to me.
What services do you have enabled? You might need to disable some of them to reduce the memory footprint.
It's also possible that your NAS is simply undersized. You have an entry-level home NAS. An RN422 is more suitable choice for business use.
nicolasg
Hi StephenB,
Thanks for your answer.
You are right. Not a Duo :)
Here are the active services : SMB, AFP, FTP, ReadyDLNA, UPnP, HTTP, HTTPS, SSH. No antivirus, no apps (I deleted the only apps we had). Hope it helps.
We have the Nas since more than 3 years and that is the first time we have these problems. Before changing model, every technical advice sounds good to me.
Regards.
- StephenBJul 20, 2017Guru - Experienced User
Do you have quotas enabled on the volume? If you do, try disabling them (this is done by clicking on the volume settings wheel).
- nicolasgJul 20, 2017Aspirant
Unfortunately, no quotas enabled.
- jak0lantashJul 21, 2017Mentor
If you're running 6.4.0, the quotas ARE enabled on the volume (quota accounting) even though you haven't set any quotas on any share.
There is no GUI option in 6.4.0 to disable the quota accounting at the volume level.
You really should update your firmware, 6.4.0 wasn't the best for ARM units. And a RN102 is not designed for professional use.
There is a good chance your volume is heavily fragmented and the NAS struggling. If you want to use a RN102 and still get acceptable performance, you need to use the correct configuration, no bit rot protection, no compression, no quota accounting, as little snapshotting as possible, etc.
If you start defrag and balance on your RN102 running 6.4.0, if the volume is in poor health, it will most likely collapse.
