klopjero56
Jan 13, 2021Aspirant
ReadyNAS Duo RND2000 V2 - LEDs Blinking don't know what to do
Greetings, I have an issue with my ReadyNAS DUO RND2000v2 When I turn it on the fan startsup full rev and will not turn down. The appliance will start blinking the following code. power and ...
mdgm
Jan 13, 2021Virtuoso
5 blinks is unsupported RAID configuration: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-LED-patterns/m-p/543991#M71
klopjero56
OK, inserted the original disks. ( i had wanted to save them in case something bad happened) that fixed the 5 blinks, now the blue power button pulsates twice and then turns off. while act blinks every second or so and both the disk leds are off.
I can't see the device on radiator yet.
- klopjero56Jan 13, 2021Aspirant
it seems to be fixed now..thanks :)
