EddVardas
Apr 12, 2020Aspirant
ReadyNas Duo RND2000 V2
Hi all, I've got an issue vith my Readynas Duo v2: after upgrade tto Windows 10 on all my computers at home, cannot connect to Nas. The same issue with my TV (LG with webOS), where I used to watch ...
aks-2
Apr 12, 2020Apprentice
You might try \\<nas IP address>\media, if not successful then please share the IP address of you PC and NAS. Has anything else changed in your network?
- StephenBApr 12, 2020Guru - Experienced User
also go into "turn windows features on or off" and make sure the SMB 1.0/CIFS client is enabled.
I suggest using the IP address rather than the hostname for now.
What firmware are you running?
- EddVardasApr 13, 2020Aspirant
Hi,
Thanks for your quick response.
SMB 1.0/CIFS client was enabled.
The firmware is 5.3.13.
Using IP address to get to the NAS. What else to try?
RAIDar shows NAS as healthy, both drives are running well.
- StephenBApr 13, 2020Guru - Experienced User
If you can access the NAS shares from File Explorer with the IP address, then you likely have a discovery issue. One workaround is to reserve the IP address of the NAS in your router, and add the hostname to the PCs' Host file.
If you can't access the NAS shares from File Explorer with the IP address, then try running the command prompt on the PC (CMD):
net use * /delete /y net use t: \\nas-ip-address\sharename /user:admin nas-admin-password
using actual values for the NAS IP address, sharename, nas admin password of course. Be careful on the typing (both slash direction and spacing).
The first command terminates any open SMB sessions; the second attempts to map the share to drive letter T.
If that works, then try the commands again with the NAS hostname. Note the first command will undo the mapping of the drive letter.
Let us know what happens with these commands.
Hi, trying to reach \\<nas IP address>\media - getting wrong password response. While connecting through the web with this password works.
IP address is shared, nothing else changed in the network.
- aks-2Apr 14, 2020Apprentice
As Stephen mentiones it could be cached credentials. Are you getting a log in request via Windows file Explorer?
What happens if you try to map a drive, selecting a specified user logon?
From a DOS Command window type 'net view' to list active connectios.
Take a look in Windows Credentials Manager too, and delete any entries to the NAS, you can then re-instate them or you'll be prompted when you make the first connection.
