EddVardas
Apr 12, 2020Aspirant
ReadyNas Duo RND2000 V2
Hi all, I've got an issue vith my Readynas Duo v2: after upgrade tto Windows 10 on all my computers at home, cannot connect to Nas. The same issue with my TV (LG with webOS), where I used to watch ...
aks-2
Apr 12, 2020Apprentice
You might try \\<nas IP address>\media, if not successful then please share the IP address of you PC and NAS. Has anything else changed in your network?
Apr 12, 2020Guru - Experienced User
also go into "turn windows features on or off" and make sure the SMB 1.0/CIFS client is enabled.
I suggest using the IP address rather than the hostname for now.
What firmware are you running?
