EddVardas
Apr 12, 2020Aspirant
ReadyNas Duo RND2000 V2
Hi all, I've got an issue vith my Readynas Duo v2: after upgrade tto Windows 10 on all my computers at home, cannot connect to Nas. The same issue with my TV (LG with webOS), where I used to watch ...
aks-2
Apr 12, 2020Apprentice
You might try \\<nas IP address>\media, if not successful then please share the IP address of you PC and NAS. Has anything else changed in your network?
EddVardas
Apr 13, 2020Aspirant
Hi, trying to reach \\<nas IP address>\media - getting wrong password response. While connecting through the web with this password works.
IP address is shared, nothing else changed in the network.
- aks-2Apr 14, 2020Apprentice
As Stephen mentiones it could be cached credentials. Are you getting a log in request via Windows file Explorer?
What happens if you try to map a drive, selecting a specified user logon?
From a DOS Command window type 'net view' to list active connectios.
Take a look in Windows Credentials Manager too, and delete any entries to the NAS, you can then re-instate them or you'll be prompted when you make the first connection.
