bjussab
Jul 30, 2015Aspirant
ReadyNAS Duo RND2120 v2 (v1) - stuck on system starting up RAIDar
Hello everyone. Hope someone can share some ideas and help me. I bought a ReadyNAS Duo in 2010/2011. I used it for a couple of years before it was left to sit on a shelf unused. I recently st...
bjussab
Hi,
Thanks all. It seems one of my drives was corrupt and was causing the issue.
I have managed to get it working with one drive in and re-setup it up using the factory reinstall method.
I have used windows disk manager and repartitioned it, hoping that when I reinsert it later on it will just Raid build up to how I want it.
Many Thanks
vandermerwe
Jul 30, 2015Master
No don't repartition the disk, this is more likely to cause problems.
Delete any partitions before inserting the disk.
Did you factory default it to xraid? If you did it will create a raid volume which seems to be what you want.
